Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-17-2006, 02:10 PM
radioman2002 radioman2002 is offline
94 to 99 Trans Swap
The transmission in my 1999 Tahoe has gone south, I do have a 1994 LT1 police wagon, with a good one. What are the chances that I could use the 1994 in the 1999? I intend to also put this question up on the GM forum
Old 04-17-2006, 10:58 PM
96capricemgr 96capricemgr is offline
Re: 94 to 99 Trans Swap
The Tahoe has an LSX engine right? The bellhousing depth is different which is a MUCH bigger problem than the PWM differences which would also pose a problem. If those still had a gen1 based motor then it would be a bit easier to make work but still not a perfect dropin.
If you have a 1A2 wagon I think you could find a buyer and if it is vaguely OK shape that should pay for a proper tranny in the truck.
Old 04-18-2006, 01:32 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
id love to find a police wagon, why not just sell the wagon and buy the proper trans
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 04-18-2006, 05:54 PM
Blue Bowtie's Avatar
Registered Offender
Which begs the question, "Why not just repair the '99 transmission?"
Outside of the little extra work in removing the transfer case, it's really a straightforward R&R, and rebuild between the two. Other than the differences in the bell pattern, it should be a straight 4L60-E.
And, just for curiosity, what exactly is the definition of "Gone South" in this case? It may be repairable with only removing the trans oil pan, in the vehicle.
