Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 04-17-2006, 01:04 PM
jpracingklub jpracingklub is offline
Post 99 venture aftermarket remote start
I would like a wiring diagram for a 99 chevy venture for a delta pro-5005 security system. This system has a ignition immobilizer, remote start, basically everything. If no one has anything like this, could you refer me to somewhere I might find one?
INCLUDES:
MAG 6 Tone 125db Siren
Main Wire Harness
2 TWO way Pager Remote
Emergency Override / Programming Switch
Dual Stage Shock Sensor
Owners & Install Manual
RED STATUS L.E.D.
Hood and Trunk Pin Switch
Protected by Window Decal
Limited 2 Year warranty from Delta or through Our Company
Includes One Ultra Small FIVE Button Multi-Channel Pager Remote
One 4 Button Standard Remote
0.7 or 3 Second Door Lock Pulse (Programmable)
Code Learning Receiver
Anti-Scan Technology
Alarm Pre-Warning
Defective Zone Bypass with Warning Chirps
Remote Panic
Starter Disable Protection (Relay Required)
On-Board Flashing Light Relay
LED Status Indicator (Plug-In Design)
Protected Valet/Programming Switch (Plug-In Design)
6-Tone Mag 125dB Electronic Siren
Passive or Active Arming Mode (Programmable)
Door Lock on Passive Arming (Programmable)
Auto Lock/Unlock through Ignition (Programmable)
Graphics Display Armed or Disarmed State, Zone Violation, Vehicle Running After Remote Start, and Valet/Service Mode
433 MHz Transmitter Frequency for Less RF Interference and Added Reliability
Penetrates through most Cement Structures,Movie Theaters,Malls,etc..
Digital Transmission Format Permits Real-Time Instant Confirmation of Arm, Disarm, Start, and Intrusion
Valet Button Operates as an In-Vehicle Call Button to the Transceiver
On-Board Relays for Easy Installation
Selectable Engine Speed Sensing: Tach Learning, Tachless, or Vacuum Operation
Gas or Diesel Engine Operation
Hood Open Safety Circuit.The Unit will not Remote Start if Hood is Open or Ajar
