Compass Wiring Diagram???
Hey guys, attempting to put the compass & thermometer into my Avenger do any of you happen to have or are able to get a wiring diagram for the compass on a 95 LHS?
Re: Compass Wiring Diagram???
Anyone at all?
If the mirror's from a 95 LHS, it only has compass. No temperature. The display is universal and can display temperature, but was not availible in the 95 LHS. If you get a mirror from a mid to late 90's GM vehicle, the temperature is availible. Check the buttons on the mirror to see if temperature is used. Auto/Comp = Dimming mirror & Compass. Comp/Temp = Dimming mirror, Compass & Temperature. These mirrors usually all used a 7-pin connector. A GM mirror will fit on your car.
1-ignition (closest to the mounting stem) 2-ground 3-reverse inhibit (12V supplied when vehicle is in reverse to override the dimming feature) not need for aftermarket hook up 4-outside mirror dimming power 5-outside mirror dimming power 6-temperature probe 7-temperatuer probe |
I'm assuming you are retrofitting a mirror. It's the easiest way to get the features you're talking about. I don't have any info on an overhead counsel or in-dash parts.
