Old 04-17-2006, 10:41 AM
waltham41 waltham41 is offline
92 Caravan Cab Module
I have a 92 caravan with the 3.3L overdrive tranny FWD. The local Dodge dealership says that the cab module is sending an error code, and that it will cost $2400 to replace it. I have tried to find it on the internet, with no luck.
Is there another name that it is known by?
Thanks!
Old 04-17-2006, 01:49 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 92 Caravan Cab Module
Look hear: http://www.autozone.com/servlet/UiBr...3d8010d825.jsp
Then look here: http://www.autozone.com/servlet/UiBr...+UP%7C%7E00320
Then drive to your local Dodge dealer and shove the bill up their collective asses!
If Autozone doesn't work out try an on-line salvage yard or your local one.
Old 04-17-2006, 02:50 PM
Talking Re: 92 Caravan Cab Module
Many thanks, that is a huge difference in price, the picture is a little vauge as to where on the vehicle this module is, can anyone tell me if it is under the dash or in the engine compartment or elsewhere?
THanks!!!!!!
Old 04-17-2006, 07:33 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Open this and scroll to CAB: http://www.autozone.com/servlet/UiBr...3d8010d761.jsp
Old 04-17-2006, 07:57 PM
Thanks again, I really appreciate the help!
Old 04-17-2006, 08:00 PM
Hoody Hoody is offline
Walt, from what I can figure and read on that Autozone site, its under the battery holder, and that the CAB for the 2WD is different from the 4WD.
I'm also lookin for a pic of where the breaklight switch is, and how much of a pain it would be to replace that if this ABS recall deal and fix doesn't stop the break light from commin on. This red light next to the ABS light only seems to come on when sitting and the engine running, when I'm driving it doesn't come on, so I'm thinkin it has somptin to do with this ABS thing too and I won't need to mess with the switch after they fix the ABS.
Old 04-17-2006, 08:40 PM
ON mine the brake warning light only flashed when you first pressed the brake pedal. It no longer does that so I hope that for you also. The list of parts they replaced for me mentioned brake switch if I remember correctly (No promises there)
Old 04-17-2006, 08:51 PM
well that sounds like what mine is doin, so cool deal if they replace that switch too. I'll make sure to mention it though when I get called the parts are in
thanks... I think this will be all I need for now on this thing till than.
