Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-16-2006, 09:32 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
vacuum lines and high idle
Well I have a few bugs to work out now that my car is running. First, and most important, the vacuum nipple on the wastegate on my 16g points in such a way that it gets pinched off by my intake(2.5") and consequently my mbc doesn't work. The only thing that I've come up with is get a smaller diameter intake. Any suggestions on that. Second my idle is ~2300. I've tried adjusting the biss and that is all the way in and its still that high. I'm thinking maybe the tps is off a little from when I put it on my new tb? And ideas on that? And third and not so important. My ic pipes keep blowing off even with all that silicone, I think I need to get some t-bolt clamps.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-16-2006, 10:37 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: vacuum lines and high idle
I'd get some t-bolt clamps. You can find sets on egay for fairly cheap. As for the idle was about the iac motor? (or isc or whatever you want to call it)
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-17-2006, 08:28 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
About the intercooler pipes: Use some t-bolts, but cant you also flare the ends of the piping a little?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 04-17-2006, 08:29 PM
blk_srt's Avatar
Yeah, I have that under control now, the biggest issue is the wastegate line
Mods:
Old 04-17-2006, 08:31 PM
Umm, maybe a picture of it would help? But I guess it would probly be hard to take a pic of it.
Caleb
vanilla gorilla
