Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 04-16-2006, 08:22 PM
workinmanfred workinmanfred is offline
Code P0172 (Bank 1)
Can anyone tell me what this code is? I have a 98 Transport Montana. The SES light came on and I immediately stopped at an Advanced Auto to get the code read. It is off now. Is this something I should be worried about? I have a 1600 mile roundtrip coming up this week and want to feel confident about this van. I wouldn't want to be stranded with my wife and 6 month old daughter. Thanks everyone.
P0172
System too rich
(Bank 1)
Old 04-17-2006, 12:23 PM
paul.v
Guest
Posts: n/a
Re: Code P0172 (Bank 1)
'Fuel Trim rich' below is for 95 but should be similar...If you need more info , send me an email..
Paul
DTC CHART TEST DESCRIPTION
Number(s) below refer to circled number(s) on the diagnostic charts.
  1. Visually/physically checking items which may cause a rich condition may determine the cause of DTC P0172 being set.
  2. A mass air flow sensor that causes the PCM to read a higher than actual air flow can cause a rich condition and DTC P0172 to be set.
  3. Silicon contamination of the Heated Oxygen Sensor (HO2S) can cause a false rich indication to be seen by the PCM. The PCM will then reduce the amount of the fuel delivered, possibly causing severe driveablity symptoms.
