Old 04-16-2006, 01:35 PM
albarran9 albarran9 is offline
Why dose it shake?
My Civic shakes some times when it's in drive 4(AT tranny) and feels like the motor is off center or like its gonna turn off and when i shift to drive 3 it goes away and feels normal. It dose this when the car is at around 30 or 40 just cruising and the shaking also goes away when I accelerate or go above 45mph. what's causing this and how can I fix this befor it getts worse or some thing breakes?
It's a 95 ex 4door d16z6 Vtec 1.6L auto tranny.
Old 04-16-2006, 05:39 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Why dose it shake?
You're putting in too high of a gear (rpms are too low) and you're bogging the engine. It's perfectly normal, just don't put it in 4th when it should be in 3rd.
Old 04-16-2006, 10:50 PM
DarrylG DarrylG is offline
thats not true, my blazer is always in '4th' gear (called overdrive on automatics) it should be shifting automatically, its not like driving a manual car in 4th gear.
I dont know what is causing it to vibrate only at that speed in that gear. Take it to a shop if it bugs you that much.
Old 04-17-2006, 05:33 AM
hany's Avatar
hany hany is offline
if it only sjake at 30-40 it must be wheels problem
but if like its gonna turn off , it may be distrebuter , fuel filter , fuel air, spark plug, or it may be fuel problem or electric problem.
and i suggest it is wheels problem because it run well again in high speed
and its so easy to solve it just go to wheels center and they will plug small metal pice in each wheel to correct the error.
MY ENGLISH IS NOT PERFECT. sorry for that
1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD
1996 CIVIC 4DOOR EUROPIAN VTEC LS
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 04-17-2006, 04:36 PM
I have already done a full tune up befor (new airfilter, oil filter,fule filter, new spark plugs and wires, new distributor cap and oil change. it stoped for a bit and then started back up again a couple of weeks later. thing is though that if i swith gears while doing the same speed it will stop shaking. i think i might have to change the tranny fluid or would that not help? or could it be my fule injectors that are dirty (i'v already used fule injector cleanders to see if it would help)?
Old 04-18-2006, 02:41 PM
hany's Avatar
before you change the tranny please check all fuses. then try other injectors. if still. try other ecu.
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 04-19-2006, 11:47 AM
absinthe5765 absinthe5765 is offline
I think im having the same problem, almost.
It shakes back and forth when im stopped and its in drive 4 (AT.) I got new plugs and a new fuel filter and it dulled a little but still shakes. If im in park, or in nutral it goes away, only when im sitting there stopped while its in drive.
Old 04-19-2006, 09:18 PM
Yeah my car dose that too. I think I'm gonna reset the ecu, but i dont remember how. I think you just have to disconnect the battery.
Old 04-19-2006, 10:00 PM
Tell me when you do, and if it helps any. Thanks!
Old 04-20-2006, 02:54 AM
meberra's Avatar
meberra meberra is offline
yeah mine does the same thing. i can really tell when it gets warmer out. like stated when i throw it in Nutral or park it stops. i heard somewhere you need to get a vaule clerance ajustment.......hmmmmm i guess this happens to alot of Automatic hondas??
Old 04-20-2006, 03:49 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Sounds like you guys just need to replace your tranny. To get it fixed would be outrageous and all the other things about chainging other parts out and doing a tune up aren't going to help. It's most likely a mechanical problem in the tranny and because it's an automatic, it's going to be more expensive to fix than it is to replace the whole thing.
AF COMMUNITY GUIDELINES
Old 04-21-2006, 10:12 PM
Pavlo's Avatar
Pavlo Pavlo is offline
I was going to say possible misfire, but most likely either tranny ecu, or the tranny.
VR6> Anything
FWD sucks for understeer? Swaybars do magic.
Old 04-22-2006, 03:28 AM
showcivic96ex showcivic96ex is offline
Send a message via AIM to showcivic96ex
i had the same prob on my 96 ex auto... all i did was replaced the tranny mounts... not sure if it would work for u because mine didn't bog down... she just jumped like mis/backfire when it switched gears...
96 civic coupe... bomex front kit + wide bodykit, lowered 2 in, no wheels, (wrecked! sitting in my driveway waiting for me to fix her)
92 civic cx hatch... lowered 17z, d16y8 w z6 tranny and p05 ecu... .http://www.cardomain.com/id/showcivic96ex
2007 honda FIT brand spanking new
1993 honda del sol Si just got it (july08) and she was beat up pretty bad
[email protected]
