Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-16-2006, 01:22 PM
EclipseJackson EclipseJackson is offline
Gear Oil (?) or tranny fluid?
I don't have my owners manual and I got a new tranny put into my 95 Eclipse (5speed) and have heard that gear oil needs to go into it? I am not sure so my boyfriend and his friends said to find out and make sure -- the part stores are completely clueless about what I am talking about.
Someone help, please.
Thanks!
Old 04-16-2006, 01:25 PM
george536's Avatar
george536 george536 is offline
Re: Gear Oil (?) or tranny fluid?
Thanks!
you need to give more info, what kind of vehicle is it rs,gs, gst gsx?
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 04-18-2006, 12:07 PM
It is an RS ....
Here is the deal. I got a transmission shipped to me from some guy in PA -- well, 3rd gear grinds and now when it was started and just sitting there (clutch not pushed in, not in gear, no gas, nothing) it would make a grinding sound. Well, my boyfriends buddy said that there probably isn't and fluid in it. We assumed that there would be since from what I understand it is inside the casing and there really isn't a way to add it (that came from the guy at the stealership, so it may very well be false.... lol)
I've had this car for 2 months and it is driving me crazy .... we can't find anyone that will help us work on this thing. It's too pretty to just give up on ..... lol
Thanks for any help/advice you can give me
Jinni
Old 04-18-2006, 12:13 PM
E-Klips E-Klips is offline
Banned
There is a fill plug and drain plug. When you take a tranny out and remove the axle shafts, tranny fluid tends to empty out the holes for the CV joints. I sure hope you werent driving the last 2 months without tranny fluid in there.
Old 04-18-2006, 12:21 PM
LOL Yeah, I should have clarified that ... we just put the tranny in 3 days ago, I drove it that night for about 15 minutes or so, not long at all and then it got parked -- just wanted to see if the tranny worked or not. It shifts like a dream except 3rd which grinds, but we are hoping that is because of lack of fluid
Is there a webpage or anything that has pictures showing where those plugs are? We can find the drain plug no prob, but the other other way that seems like it could get fluid is would be by taking out the speed sensor -- and that doesn't sound like a good idea.
1995 Eclipse GS 5-speed
Megan Racing Header*Megan Racing Catback System*AEM Cold Air Intake*Tokiko Shocks*
Eibach Springs*Nology Plug Wires*NGK Plugs
Old 04-18-2006, 01:09 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Nooooo, very bad idea. The fill hole is on the front side of the tranny about half way up. You need to use some type of pump to fill it to the bottom of that hole. I cleaned up an old soap dispenser pump and put a hose over the end of it and ran it into the fill hole.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-18-2006, 01:23 PM
Very cool, as soon as my boyfriend gets home I will tell him that is where it is located at -- thank you, everyone, for your help!
Old 04-18-2006, 02:03 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
its on the driver side above the axel its a little black plug about 2" in diamiter. not hard to find .
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 04-18-2006, 09:38 PM
Banned
Taking out the speed sensor and putting fluid in there isnt going to hurt anything. It all goes to the same place. The fill hole works too, and it usually goes in faster with the fill hole. The only thing at the bottom of the speed sensor is the differential which is covered in gear oil anyways.
Old 04-19-2006, 12:12 AM
Yeah, I know its all the same. But you have no clue how much to put in it then. Its just a much better idea, i think, to put it in from the fill hole and get the correct amount in it.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-19-2006, 12:25 AM
Banned
Either way works. If you take the fill plug out and put the gear oil in through where the speed sensor is located then you can get the correct amount. A little easier to fill also. Some people overfill the tranny through the fill hole seeing there is a tube stuck in it and most of the time they have the car jacked up, which is not the correct way to do it unless it is on 4 jack stands.
Do it however you like and what seems right/easier, doesnt matter.
Old 04-19-2006, 01:22 PM
Ok --- you guys say "gear oil" a lot .... we were told to put Pennzoil Synchromesh in it .... do I need to put gear oil in it instead of that Synchromesh? We are going to be trying to find that plug here in the next day or two, as soon as my boyfriend has a day off so he can see during the day what he's looking at.
I am going to go back out and try to find the plug, I didn't see it before, but the "above the axel, about 2" plug" should narrow it down pretty well for me. lol
Old 04-19-2006, 01:59 PM
Ok ... I am going to go ahead and try to help out my boyfriend just a little bit, if I can find this plug, I can fill it myself -- can anyone see it on these pictures? I ran out and took these pictures real fast ... lol ....
Old 04-19-2006, 02:01 PM
Old 04-19-2006, 02:02 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Put in Synchromesh.
95 Talon TSI AWD
97 Eclipse GST
