| B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version. |
Have to pull the motor to replace Timing Chain on 91' B2600i 4x4 ?
Do you have to pull the motor to replace the timing chain on a 91' B2600i 4x4? A couple years ago I had to drop a motor in the truck after 190,000 miles. I bought an ATARCO used Japan motor and just swaped it out. 8,000 miles later (I live a mile from work so it took that long to get 8,000 miles
) the head gasket blows on the replacement motor. I pulled the head and found all the bolts holding it down were not torqued and could easily be removed with light pressure. The machine shop said I would need a new head and cam (cam because the bolts were lose and warped it). I opted to surf Ebay and found a company in TX that sells completly rebuilt heads for $350.00 and bought a head gasket kit for another $50. Getting it all apart was easy but rather than mess something up I took it into a shop so they could set the timing and drop the new head on. Phone call says the marks on the timing chain are gone and I will need a new one. No problem as they are $30 at NAPA. Only catch is the book says you need to pull the engine to do so and that is an 8hr job @ $82 hr shop time. Total to do it all is almost $1500. Has anyone ever replaced the timing chain? If so do you need to pull the motor? Thanks in advance from a newbie! Jeff jduck1 |
Re: Have to pull the motor to replace Timing Chain on 91' B2600i 4x4 ?
I don't have the answer you need, sorry, but I have a similar problem. Can you give the info on the place in TX you got the head and head gasket. Thanks.
You don't have to pull the motor to replace the timing chain, but you will have to tear it down pretty far to do it. I just finished doing this and its about a draw as to which way is better. Good luck!
