Old 04-16-2006, 11:44 AM
mike123 mike123 is offline
93 1500 half ton
so this is what happened , i was driving home yesterday doing about 65 long drive all went well but then all of a sudden i noticed , like a bogging down , and my rpms would twitch up just a little bit when it did it ,
i was kinda low on gas i thought my gauge might have been off a little and was runing out of a gas , at this time the problem wasnt too bad , would only happened when i would try to accellerate and raise the rpms , so i got off and got some gas , now i was tryin to see if the problem was still there so i was take off and see if it sloved the problem nope didnt work , okay so back on the road i went
got about another 3 miles and the problem got worse , so i pulled off to check my fluid levels (which were fine)
then i get back in and start it , now the problem has goten worse, it doesnt idle right right , it strugles i would say , and when you put it in drive and strugles against the torque converter and would die , if not die it would idle real bad and when you went to give it gas rpm would raise then drop raise then drop so whatever i had it towed home
when i got home i started to look at it , i pulled my air filter off and would start it , sounded a little better with the idle but still had the issuse , but when i put it back on and started it died imedietly(horrible spelling yesi know bare with me) then would not start , i only tried a couple times cause i cant aford to run my battery dead not at my house with all my tools
now my question lol
what could be causing the problem , or is this a known problem , have never had any kinda issuse
with the truck ,
my thought were maybe bad cat converter or cloged fuel filter my air filter was in good shape that wasnt the issuse
just tryin to get an idea of what you guys think
Old 04-16-2006, 12:07 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: 93 1500 half ton
First off wrong forum but hey, we can all offer some advice. Mine would be to start with a tune up if it has not been done lately; cap, rotor, plugs, plug wires, air filter and new fuel filter and probably could not hurt to pour some injector cleaner in the tank after too. My guess is that it is probably a clogged fuel filter, but some may say that maybe the fuel pump is dying but i doubt it, they did not start having problems with the fuel pumps till around 99. At least it is a place to start.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 04-17-2006, 01:59 PM
so yes , i got a nice day of sunshine , i changed the fuel filter it was cloged no doubt , but now i cant seem to get it to start , i can prime it alittle get it to go but wont continue , i pulled the exit side tube out on the fuel filter and turned the ignition on hoping it would start the pump and fuel would start coming out didnt happen , is this cause there is a break in the loop? or should it pump fuel? or does it have to start ?
just tryin to find a way to check to see if the pump is working without spending 45$
Old 04-17-2006, 03:10 PM
chevrock22's Avatar
chevrock22 chevrock22 is offline
I would start buy posting this in the c/k forum, were trucks of your kind are. Im not tring to be rude im just saying that you might find your problem resolved there.
Old 04-17-2006, 04:18 PM
will do
