Old 04-16-2006, 11:04 AM
boucher7 boucher7 is offline
installation of eurolite instrument cluster....help needed
I have all the connections in the cluster but there is a box im assuming its for the dimmer switch.. Anyways, everything works excepts for the back lights so i can't drive at night, the box has 2 wires, one black and one red, im not sure where these wires are supposed to hook into, any help would be appreciated
Old 04-16-2006, 09:24 PM
songsandstars's Avatar
songsandstars songsandstars is offline
Send a message via AIM to songsandstars
Re: installation of eurolite instrument cluster....help needed
give some more detail. you insalled the cluster and then there is a seperate external box with a red and black wire running form it? is that correct? also, did it come with a dimmer or switches? hit me back...
Old 04-16-2006, 09:48 PM
yes the box is hooked up to wires that go to the back of the cluster, going from the external box is a dimmer switch, then there are the 2 wires also coming out of the box, im assuming i have to tap into the existing factory dimmer switch, it has 3 wires, one black, i think one is red and the other is both black and red, do i hook black to black and red to red, let me know if thats enough information or not, thanks for replying
Old 04-17-2006, 04:54 PM
http://www.wickedwayzcustoms.com/5thgauges.html
let me know if you have any questions :-)
