Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 04-16-2006, 11:00 AM
74NovaNick 74NovaNick is offline
starting issue needs resolution
Hey AF,
I wanted to throw another problem I need some help with. My 74 Nova will start on any good day. The carb. sounds great and all will be well....until I turn the ignition off. I'll try to start it again and I'll get NO SPARK! The car will not start for another couple hours. The battery is running around 12.3 volts so what could be the problem. Any advice would again be appreciated. Thanks.
- Nick
Old 04-18-2006, 05:38 AM
NOVA71's Avatar
NOVA71 NOVA71 is offline
Re: starting issue needs resolution
You could try replacing the ignition module in the distributor. When they go, they tend to do what you are describing (sometimes there's spark, sometimes there isn't). The module is pretty cheap and easy to replace. Hope this fixes the problem. Might want to throw on a new cap & rotor button too if you haven't replaced them in a while.
Current Rides:
1971 Nova
2004 Tracker
2013 Sonic
Past Rides:
2007 G5
1984 Firebird
2000 Jimmy
1994 Jimmy
1990 Tracker
1985 Jimmy
Old 05-10-2006, 12:36 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Good call Nova71. They get hot and break down... leaving you stranded for a few hours until it cools off.
Bob
