Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-15-2006, 11:23 PM
Cain98Eclipse Cain98Eclipse is offline
Send a message via AIM to Cain98Eclipse Send a message via MSN to Cain98Eclipse Send a message via Yahoo to Cain98Eclipse
Couple of ¿'s any answers very appreciated
1st ¿ when racing your car (my car is stock) would you take it up to the redline (7000rpm) before you switching gears? Will this hurt the engine? If you change before the redline (6000rpm) would this be acceptable and not hurt the engine¿ When they test cars what rpm do they switch at?
2nd ¿ I have a 98 eclipse and was wondering if everything on a 95 talon would be just the same as a 98 eclipse, more specific the engine, exhaust, and short throw shifter?
Old 04-15-2006, 11:29 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Couple of ¿'s any answers very appreciated
the stock turbo on the 4g63 doesn't make much power past 6000rpms, I would shift there.
now - 2000 civic
soon - 2002 is300
Old 04-15-2006, 11:47 PM
snoopyloopysk8a snoopyloopysk8a is offline
depends on where the tune of your car puts your powerband. so this isn't really a straight answer question. but if it's in good condition and since you said it's stock, it's probably around 6000, like the other fellow said.
you can swap them between bays, but it depends on what engine each has will determine if you can swap things like heads or exhaust manifolds, etc.
Old 04-16-2006, 12:54 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Before answering this question, we need to know if you are turbo/AWD/NA and if the Talon is turbo/AWD/NA. Everything cosmetic can be used and should fit, including the shifter.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-16-2006, 09:21 AM
ned032002's Avatar
ned032002 ned032002 is offline
Just for kicks, could you put your car in your sig cause that will help with any other questions that you have.
Old 04-16-2006, 06:53 PM
Thanks for all the responces, they helped alot. As for the everything else, my car is a 98 Eclipse RS NT yeah I know I should sell it and get better but I cant. No money!! The Talon was a 95 NT so they would have fit but they guy sold it already so I guess I will just go look around the junk yard or see what I can find. I would post pics of my car but I dont have any and before I bought it the guy painted it and it looks gay. And I would paint it but I want to get a body kit first no since in painting it and then having to paint the body kit when I get it! And again thanks for the reply's!
