Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 04-15-2006, 09:52 PM
Capt.Howdy06 Capt.Howdy06 is offline
Question fiero wont start PLEASE HELP!!!!!!!!!!!
i have an 86 4cyl adn i cant get it to start ive replaced the starter the coil the plugs wires and cap its getting gas but the only way it starts is if i pour gas directly into the throttle body but it dies aas soon as the lil bit of gas i puoured in runs out PLESE HELP!!!!!!!!!!!
Old 04-16-2006, 09:51 AM
84fiero123's Avatar
84fiero123 84fiero123 is offline
Re: fiero wont start PLEASE HELP!!!!!!!!!!!
Sounds like the injector is cloged. you said its getting gas. Can you see it spraying out of the injector? If not check with a test light at the injector wires and make sure you are getting a pulse at the injector, if not its in the wireing.
technology is great when it works
but one big pain in the ass when it doesn't
Detroit Iron Rules, all the rest are just toys!
Old 04-16-2006, 12:44 PM
its not spraying it just kinda dribbles out
Old 04-16-2006, 05:13 PM
i do have power at the injector wires but the fuel just dribbles out of the injector
Old 04-17-2006, 08:44 AM
84fiero123's Avatar
Clogged injector. Take the fuel filter off and pore some injector cleaner in there, then use the gas to keep it running while you are getting the injector cleaner threw the injector. If that doesn’t work you may need a new injector.
It’s supposed to spray out in a pattern like a cone.
Old 04-27-2006, 02:22 PM
well it turned out to the very last thing i checked and replaced.......THE FUEL PUMP!!!! now it fires rite up now i just have to replace the tranny lines and im good to go thanx for all the help it is very much appreciated
Old 05-27-2006, 07:10 PM
hey thanx for all the help guys i got it running now YAY!!!!! but the brake lines were rotted and so were the tranny lines but im in the process of replacing them
