A little confused
Hi
Today I had the strut mounts on my Monte carlo replaced. When the mechanic was finished, he said that he could't start the car. I have a Python anti-theft remote control ( in a draw at home) but never had to use it. I'm the 3rd owner of the car, and figured the alarm was diconnected or wasn't working no more. He was able to get it stared by bypassing the device with a switch under the dashboard. When I got it back home, everytime I unlock the door, pop open the trunk, or start the car, the alarm goes off. (This never happened in the past 3 yrs) Also, the radio had to be reprogrammed as if the battery went dead. It also has a anti-theft device. Plus, now the "anti lock" light is on, but nothing wrong with brakes. Is this a coincidence that something went wrong with a computer chip, or could he have done something to cause all these problems to occur. All he did was changed the strut mounts. He said he didn't touch anything else. Thanks for any comments. Joe |
Re: A little confused
I'd double check all your battery cable connections and cables for corrosion. Also have the battery tested. Everything you're describing only has one common element, it's all electrical. There is no other correllation between the problems you are having.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Ok if you took it to a shop, then the first thing the mech prolly did was disconnect the bat (hence having to reset your radio) and you could have had a old alarm system on the car that was triggered when he hooked the bat back up
