| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
New Rod/Piston combo.... motor is ripped down to block!
Alright guys here it is 91 GSX motor completely torn down to the block. In taking out the crank i noticed the bearings had grooves in them. Enough so you can feel them with your finger. So im guessing thats bad. This week I am going to clean the block and off to the machine shop goes the motor. The following will be done:
Clean and check Block $100~ Balance rods, crank, flywheel $150 LongHone? $95 Re-do rods $50 Grind and polish the crank $85 Put pistons on Rod $35 Now after this I'm looking to invest in new rods and pistons. and bearings (??Clevite 77's??) Spelling is wrong...way wrong... Heard about eagle rods with what pistons? I'm looking to run 16-18 PSI of boost w/BIG16G turbo, Apexi N1 Cat back, Apexi N1 Down pipe, maybe a highflow cat, stock SMIC... Other than that (i'm on a quick note, i have to get to work) I'm looking to stay within reason with $$ but have a motor that i can take to the track and turn up the boost and be safe(want to beat dads 2006 convert corvette 6 speed (non z06). So yea. I kno i have to upgrade fuel system inorder to run higher boost, but i want my motor capable of it. Would you guys get an electric boost controler or a manual?... GOT TO GO TO WORK! ![]() ![]() Thank you guys! |
Re: New Rod/Piston combo.... motor is ripped down to block!
Clevite is spelled correct, and they make a good product. Sounds like you already have a good plan, so what are you asking? All of the major aftermarket companies make good pistons, so it's just a matter of personal preference really.
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
When i was getting prices for maching every shop told me (well the ones with dsm experience) the 4g63 was already pretty well balanced and a balancing would not do a whole lot. Might save you $150.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
Save another $50 on that re-do rods stuff. You can deburr and polish them at the house, to get rid of heat risers.
haha tonight i just bought another GSX... 90' 5 speed, perfect tranny, strong running motor hitting 12 boost solid for 200$ completely stock. when i go back tomorrow im goin to do compressoin test... that shit runs 160 im buying that! lol when will this shit ever end?! Not going to rebuild the motor, instead do a swap. put the 90 motor in my 91. Doing the timing belt along with balance shaft elimkit. Should be fun! lol man finding theses cars are easy... are balance shaft elim kits hard to put in?
You bastard! lol, man you are having some good luck. Can't wait to hear how it goes tommorow.
![]() 2006 Wicked White Evo IX GSR 323 awhp / 311 tq. (Dynojet) http://www.projectevoix.com http://www.4WStuning.com 99 RS < 98 GSX < 06 EVO
Geez, pass one of these 1g's my way so I can finish my car.
-Brian
Yeah me too! I wouldnt mind a car just sitting around for some parts
. Got your PM, I'll get back to you.
I used JE pistons on my car.
Good stuff. You should be able to pick up a new crank for cheap If you are going to do all that. For a little more you can just bore the block out and get a 2.4 crank and wala you have a stroker motor.
1991 GSX 2.3 Stroker |
thats it? just that easy?
Yep not hard at all. I'm pretty sure it's just a .020 over bore and a 2.4 crank. I found this site Here is some info on the stroker, and at the bottom there is also another link to a page that is more in plain english for it. Explaining that you have to bore the motor out from 85mm to 87mm http://www.wideopenwest.com/~ksmith3...smstroker.html
