Old 04-15-2006, 05:50 PM
Xale's Avatar
Xale Xale is offline
Miles Per Gallon Loss?
hey, I am looking into buying a Honda CRX. I recently found a Manual 1991 Honda CRX HF, with 193k miles on it. The one thing that I am not sure about buying it for: the owner says it gets 25mpg. I thought that was horrible considering what they got new. I can expect the mpg to go down some, but I really didn't expect it to be that low. Am I wrong or is this car not worth buying?
Old 04-15-2006, 06:05 PM
clantz86 clantz86 is offline
Re: Miles Per Gallon Loss?
Could be a couple things..
-Perhaps he likes to burn the crap out of the car? That could cause low MPG, but if that is the case, it's not worth buying :P
-The car may just need a good tune up, a little TLC perhaps
-Check the spark plugs...if there's a problem with the engine, you might find it here. He shouldn't have any problems with doing this, and if he does, he's obviously hiding something. Exhaust might be restricted somewhere, or the air filter could be clogged also. (I noticed my mpg's going down, and decided to check my air filter...problem solved)
-If it's an HF, you might want to consider an engine swap anyway
Old 04-15-2006, 07:25 PM
Xale's Avatar
Thanks. And yeah, this would be my first car with a limited budget, so I wouldn't be able to do an engine swap right away. I'll talk to him about the spark plugs, and see if I can look at it again.
Old 04-16-2006, 12:37 PM
skotman's Avatar
skotman skotman is offline
worst any crx i've owned has ever gotten is about 30mpg.
i've noticed that my gas milage goes down slowly over time. lately i've been averaging 33mpg which is horrible considering that it got 37mpg 2 years ago and i've done all sorts of improvements, always keep up with oil, i've changed the plugs, wires, cap and rotor, timing belt, broke the distributor and changed it, etc etc etc. the only way to bring it back up again seems to be to burn through a tank and a half of gas in a day, like driving from here (picayune, MS) to atlanta, GA. any time i make a trip like that i get 42mpg. a whopping 9mpg improvement by doing nothing but driving. is this telling me that i've got crap somewhere in my fuel system? i've run fuel cleaner of all types through it and i get no improvement, again, unless i burn through a whole tank of gas in a day.
i'm wondering... is my throttle sticking to where i'm constantly leaking gas into the cylinders after the car is off, at least for a short time? i do know that my car will not start right after i shut it off. i've got to wait 10 - 20 minutes, but haven't been able to figure out what's causing this.
Old 04-16-2006, 04:01 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
the HF should get 40-50 if it's in excellent running condition, it might take allitle work and some knowledge but you could probably get it there with a small amount of cash, unless the engine is shot to hell in which case you would want to put a new B7 in there which is also cheap, but requires <b>some</b> knowledge and tools.
Old 04-16-2006, 04:29 PM
cpolaris502's Avatar
cpolaris502 cpolaris502 is offline
my mileage has been acting really strange lately. Ok, i bought the car back in december, the first tank of gas i put through in it i was drivng it really hard and seeing what it can do, redlining alot and what not. - I got 29 mpg. After that it has been bouncing all around, the worst mileage i got was 19MPG! Then i got 25 after that. Weird thing is now im halfway through a tank of gas and i have 150 miles on it, when usually i will have about 100 on a half tank. I dont get it. i been driving it prety consistent too.
I need to do a tuneup though, what kinda of things should i check/replace?
Old 04-16-2006, 07:20 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
To tune up you should change:
Air Filter (If dirty)
Distributor Cap (If lots of oxidation residue)
Rotor (same as distributor)
Spark Plug wires (If in bad shape, torn, or peeling paint, take them out and inspect the actual metal wires)
Spark plugs (easy to do and woudlnt hurt to change anyway)
Change PCV valve? (may help with gas mileage and aid oil consumption)
Clean EACV
Possibly change O2 sensor if old
Change oil to nothing higher than 10W30 (5W30 preferred)
Am i forgetting something?
PS make sure to inspect your plugs after taking them out...
GL
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 04-16-2006, 07:57 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Well on a tune-up I would drain and change the trans fluid. Check clutch adjustment (a slipping clutch makes bad mileage too). And inspect your cv axles and brakes...if the cv's are binding or brakes are dragging your just eating up mileage and part wear.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-17-2006, 08:59 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Clean EACV
GL
This is all good... see my response to your other thread. Also, poor tire inflation can give shitty gas mileage. True story.
Just thought of something, car could have big heavy rims which would give shitty gas mileage to a car that is slow and may have been riced/raced.
Or the car could have an engine swap already or all of the above, but I've even heard of b-series getting 30mpg, unless turboed.
GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 04-17-2006, 09:22 AM
FrodoGT's Avatar
My B gets 27mpg, and im on it at almost every opportunity (not screaming to 8k mind you), I also have shitty wiring,and right now Im throwing 2 trouble codes because Im a lazy ass and dont want to go pull a knock sensor...
Current project:
Rio Red 91 hatch.
Old 04-17-2006, 01:40 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
nope. After the car is off, no more fuel is injected, regardless if the throttle is open or not. And the not starting problem is most likely a main relay going bad. that's exactly what they do when they start to go bad. It may also be your coil or ignitor. I've never seen it be anything else.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-17-2006, 03:23 PM
FrodoGT's Avatar
Fuel injection is just that...a current is sent to thge injector telling them to open and release the fuel into the intake...when the car is off, the injectors close, the fuel pump shuts off and no more fuel is released...
Current project:
Rio Red 91 hatch.
Old 04-17-2006, 08:00 PM
Clean EACV
GL
Which of these thing in this list wouldi see the biggest MPG increase from doing.
Changed tranny fluid today and spark plugs, cleaned out the eacv with carb cleaner and air compressor, my air filter is good and so is the engine oil.
Old 04-17-2006, 10:47 PM
Concept Tuning's Avatar
Concept Tuning Concept Tuning is offline
Tire pressure is a big one. I can tell when my tire pressure starts to drop cause I get piss poor gas mileage. Another thing I have noticed is that I get better gas mileage on "name brand" gas. Those cheap gas stations can have additives. Might want to check and see if they are adding more ethanol to their mixture. That would give you a drop in MPG since it takes twice as much alcohol to make the same power as gasoline.
Old 04-18-2006, 01:26 PM
FrodoGT's Avatar
Tire pressure is definately big, for 25c you can get at least 5mpg if your tires are improperly inflated. Also, alignment is big as well, and itll wear your tires out at the same time..double whammy!
Current project:
Rio Red 91 hatch.
