Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-15-2006, 04:30 PM
mnymn3 mnymn3 is offline
1996 with major electrical problem
i have a 96 Se with some electrical problems. power windows and locks stopped working, then engine shuts off when put into drive or given any gas. this problem is intermittant. I replaced the ECM last year. car will start but dies when given gas, but the windows and locks stay not working. im assuming that whatever the problem is that the fuel pump is controlled by the same thing that the windows and locks are, therefore they car dies.
Old 04-17-2006, 08:56 PM
jdq jdq is offline
Re: 1996 with major electrical problem
Is your carpet get wet at all, possibly a ground issue.There should be a ground beside driver seat under carpet maybe corroded.Just and idea , has happened I read.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 04-18-2006, 05:56 AM
yea, thats exactly what it was, i found it on another forum, but thank you. now i gotta find my water leak.....
Old 04-18-2006, 07:44 AM
sixsmiles sixsmiles is offline
I had the same problem with a 95 engine dying and found a bad engine ground. Actually ran new wire from block to h frame.
Good luck.
Old 04-18-2006, 09:45 AM
jdq jdq is offline
Leak may be from sunroof drain
Old 04-18-2006, 04:59 PM
i dont have a sunroof
Old 04-18-2006, 06:26 PM
jdq jdq is offline
On my 90 sse I had a leak thru windshield trim .
