Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-15-2006, 02:20 PM
Chen's Avatar
Chen Chen is offline
OBD2 vs. OBD1
I just came across this article when I was surfing around.
http://www.ntpog.org/mods/fifth-afc/ecu.shtml
This is the first I've ever heard about this. Any input?
89 CRX SI - ZC DOHC, lambo doors
89 CRX DX - H22 in the making
04 G35 Coupe
Old 04-15-2006, 05:27 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Re: OBD2 vs. OBD1
Well, it's true that the OBD II system will detect and compensate the mods that you do on the engine performance (by using the second O2 sensor), that's why alot of people use the OBDII-to-OBDI wire harness to swap in an OBDI ECM.
Basically, the link is just showing you to put a switch inline with the backup memory power source to the OBDII ECM (so you can reset the ECM memory when you are not driving your car), but I personally don't see why this will help in anyway.
By putting the switch in, you are not allowing the ECM to store the fuel map that's best for the engine to perform for fuel efficiency when the engine is off. As soon as you start the engine again, if the engine is in close loop mode, the ECM will start to "detune" or compensate the mods that you did (we are talking about minutes).
So, unless you really need that few minutes of "non-regulate and not necessary the best tuning for your mods" engine run time, I don't see the point of doing this.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 04-15-2006, 09:41 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: OBD2 vs. OBD1
old news.
http://www.pgmfi.org/
read up.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 04-16-2006, 03:34 AM
Chen's Avatar
Re: OBD2 vs. OBD1
Hey thanks for the link
04 G35 Coupe
