Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 04-15-2006, 11:48 AM
sandydawn83 sandydawn83 is offline
99 Old Siluette Problem
AND SO DONT KNOW WHAT IT IS!!
Ok here the problem i had went out and ran som errans everything was fune then when i get in my car to head home. I noticed when i put on the break the hazard lights are dim but are on so i check to make sure i didnt accidently him to button and nope id idnt.. anyways then when i went to back up my ABS light and TCS like comes on.. I get a bit overwhelmed cause i have no clue what the heck is happing.. Then yesterday i went to take it to get it checked out and when I got in the car there was no problem and seemed fine.. Then when i elft this morning to go to work I noticed it was happening again.. Seems to only happen when the headlights are on... I have no clue what it could be so any help is great!
Old 05-17-2006, 09:37 PM
smudjs2000 smudjs2000 is offline
Same here??
I got a 2000 GLS :when I put the right turn signal ,and I press the brakes ,my hazards dim then stop as soon as I let go???TCS off turns on as well ALSO Gas Gauge goes a lil crazy (up and down) sometimes ????Help Please!!!!!!!
Also shouldn't the power sliding door have a sensor so that If someone's still standing there it stops??? because mine's doesn't???
Old 05-18-2006, 09:44 PM
Re: 99 Old Siluette Problem
HELP ,SOMEONE!!!!
Old 07-06-2006, 08:21 AM
johnoz johnoz is offline
Check your tail light assm. for moisture or cracks.
Remove bulbs, check for corrosion.
Check trailer wiring harness for cuts or bare spots.
Old 07-31-2006, 12:38 PM
merc81 merc81 is offline
Had the same problem. Mine was the tail light connector where the harness plugs into the PCB. Moisture collected in the plug and began to eat through the plastic housing. I cleaned it once, but that wasn't good enough. Had to go back and use a dremmel tool to play dentist and grind away all the charred plastic. After careful grinding and cleaning, and the addition of dielectric grease to keep out water, the problem has gone away.
