Go Back   Automotive Forums Car Chat > Ford > Contour
Old 04-15-2006, 09:50 AM
JoeSerpent1 JoeSerpent1 is offline
where is the pcv valve and how to I change it 95 contour
My 95 contour started having problems yesterday it is manual trans. it hiccups when I give it too much gas not so much in 1st or 2nd gear but 3rd 4th and 5th. If then will run a little rough but then smooth out and be fine. Any ideas????? also where is the pcv valve located? and how do I change it?
Old 04-15-2006, 03:03 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: where is the pcv valve and how to I change it 95 contour
get the car on ramps, climb under and look up behind the exhaust manifold. its right there. you need a flat head screw driver and small hands. I HAve pretty big hands and it was a PITA!
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-14-2006, 08:51 PM
Turrry Turrry is offline
They are cheap, but way too much of a PITA in my opinion to change. I've never had a car simply have a PCV valve go bad, usually it's various things causing the problem, the PCV valve being the least of them.
Terry Spalding,RN
YMT-M
Current Vehicles:
1998 Contour SVT
Mods: BATS fully adjustable suspension package, B&M Short throw shifter, Borla Exhaust, European Ford Modena wheels
1969 SS/RS 396 Camaro Convertible
Mods: Nothing, slight restoration in progress.
