Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 04-15-2006, 01:25 AM
Drewet88 Drewet88 is offline
Thermostat
While I'm on the forum I decided to ask a question thats been bugging me for about a month.
What happens when you put a thermostat with a higher or lower temperature?
I mean whats the pros and cons of changing the temp of the thermostat that you are using?
Sorry if it is a stupid question I just was wondering.
Old 04-15-2006, 04:13 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Thermostat
A lower temp thermostat can cause better performance as it keeps the air going into the engine cooler so you get more power. A higher temp stat will help with gas mileage but the performace may be lacking. Be careful though because too low a temp stat can cause issues with the fans not coming on when they should and the car will overheat.
Old 04-15-2006, 10:53 PM
Re: Thermostat
So lower temp helps engine performance
And higher temp helps gas mileage
I think I'll just stick with the factory stat.
At least until the one I have goes out...
Then I might change temp and see if I notice a difference.
Old 04-16-2006, 09:55 AM
Pontiac Guy
Re: Thermostat
An excellent choice!
