Old 04-14-2006, 11:29 PM
e-flightvic e-flightvic is offline
B18C OBD1 codes?
Hi,
I purchase a 89 civic with a b18c in it, with what I found out later was an obd0 ECU and the distributor too!
I swaped the distributor because the bearing failed(what a surprise) but once I replace it. The car ran fine for 2 min. then It started chocking and the "check engine" light came up
Does any one here has some advice on how I can read the codes?
thanx
Vic
Old 04-15-2006, 02:55 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: B18C OBD1 codes?
http://www.honda-tech.com/zerothread?id=682412
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 04-16-2006, 09:27 PM
Thanx but that info It's for OBD1 and up systems. I have a OBD0 Civic!
Old 04-16-2006, 10:41 PM
AF - Advisor
you have an obd0 chassis, but, you are running an obd1 engine
Old 04-17-2006, 06:39 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Ok, your problem is this...
You are running an obd1 computer so you don't have the blinking LED to check the codes. And you have an OBD0 car, so you don't have the service connector to be able to jump it and watch your CEL blink right?
If that is what you mean...then here's the solution. Take pin D4 (OBD1 service connector wire) and ground it. You can do this by unpinning it and grounding it. Or you can just tap a wire into it and ground it that way. This will make the CEL on your dash blink like it was an OBD1 vehicle.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-17-2006, 09:13 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Wow that is so damn cool. I learn new stuff everyday!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-17-2006, 10:57 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
what ecu is it?
and just becaust its an obd1 motor dosnt mean he cant run it obd0... thats how my sedan is setup.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 04-17-2006, 01:14 PM
bambam89lx's Avatar
AF - Advisor
Originally Posted by civic_boy91
what ecu is it?
no crap. But he IS running an OBD1 computer. OBD1 is better for tuning purposes.
Old 04-18-2006, 07:50 AM
I have a PR3 ECU and I think that's a OBD0 computer, I also notice that the Distributor It's not what it came with the engine!
Did I mention that I purchase this car with the engine already installed?
I went to the people that did the swap, and they wouldn't admit that they backdated the system to an OBD0. Although I did notice that they reuse the single wire Oxygen sensor compared to the 4 wire OS thats supposed to be with the OBD1 system!!!
thanx guys............
Old 04-18-2006, 11:04 AM
bambam89lx's Avatar
AF - Advisor
They made a few OBD1 PR3's too...but since you are using a one wire o2 sensor, i would say you def. have an OBD0 PR3 computer. That means you MUST use an OBD0 distributor for the car to run. Just count the blinks on your ecu to read your codes. At first you said you had an obd1 setup. There's nothing wrong with the way they set it up.
Old 04-18-2006, 04:57 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
to read the codes take the plate off the ecu look at the little led light it is red. start the car. the light will blink. long blinks are a value of ten. short blinks are a value of 1. then go to google and type in honda cpu codes all the codes you coulod ever need will pop up. print them all off and save them for the next time your poping codes.
Old 04-18-2006, 06:37 PM
thats the PR3 code list
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
Old 04-21-2006, 08:01 AM
Yes, I did the mistake of listing obd1 instead of obd0...
I'll check it out
