Old 04-14-2006, 10:44 PM
horsebro horsebro is offline
launch technique
share your different launch techniques for nearly stock 4th gen. f-body
Old 04-15-2006, 12:45 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: launch technique
Rev it to the closest RPMs you can to the HP peak of your engines, but not too high that you break the tires free.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 04-15-2006, 01:30 AM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
manual or auto?
manual: rev the engine just a little bit and when the light turn green let clutch and hit the gas halfway down, once the car moves then floor it.. from a dead stop if u floor it, your opponent, will say goodbye to you because you will be spinning whole time..
auto: put on DRIVER, hit the brake and rev the engine untill the tires hardly grabs the ground then when the light turns, let the brake and floor it..
do not shift on auto, believe me it makes u slow down.. because when u shift on auto, it doesnt grab the gear right away..
Old 04-15-2006, 03:44 AM
thanks, more specifically I have a manual 00' SS with only the basics, MAF, Catback exhaust, slp airlid, computer reprogrammer, k&n filter.
Old 04-20-2006, 07:27 PM
doodad's Avatar
get drag radials since the summer is coming.. then u wont have spinning problem a lot. if u get drag radials, rev. the enginelike 3k RPM and when the light turns green, pop the clutch and floor it. thats how l would drive.
