Old 04-14-2006, 08:34 PM
94VL 94VL is offline
Radio Details
If anyone with a 1991-1994 Cavalier with stock Delco radio,could pop off their radio/heater bezel and take a digital pic of how the radio is hung...I would be rather thankful.My 94 was a radio delete car,and the original dealer put in clunky Panasonic unit that uses the adapter that sticks out an inch or more from flush,and I want to re-install a Delco unit....however the dealers are useless when trying to order the correct bracketing.They dont have a pic available in their computer system.I need an image or (even better) part numbers of the pieces needed to retrofit a stock Delco unit.
Old 04-14-2006, 09:33 PM
ThatSoundsBad! ThatSoundsBad! is offline
Re: Radio Details
hey, they hang on the delco is really simple, the delco takes up the entire space in there, and the stock plug will go right into the back of it, as for the panasonic, when you pull off the bezel the adapter should be held in by two brackets with Torx screws holding them down on the bottom, when you remove the panasonic, take those wo brackets and screw them into the bottom of the delco, I actually have a Delco Radio from a 94 cavalier that i don't need, make me an offer for it if you want, and we can work from there, i may actually be able to get you the brackets if you need those as well
Old 04-15-2006, 05:14 PM
Re: Radio Details
Turns out the radio I have is wrong.Its from a 1992 Grand AM and mounts differently.It hangs from the top by 2 studs.Also,the antenna plug in is smaller than the cable end in the Cavalier.It looks to be in excellent condition,but how I have no way to test it,I cant say how it runs.Any offers for it? I'll take bids.....
Old 04-15-2006, 09:31 PM
Re: Radio Details
do u need a delco from a 94 cavalier? i still have my old one.
