Old 04-14-2006, 05:35 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
ls tranny on b16a
ok so i have the b16 now and i need a tranny so i looked around and found an ls integra tranny with 71,000 miles on it out of a 90 93 integra. so what i want toknow is will it work like any other b series tranny? what are the pros and cons of the ls? and caould i use the stock integra mounts for the b16 in the crx or what
Old 04-14-2006, 07:20 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: ls tranny on b16a
The ls tranny is hydro, so you need to buy the hydro conversion kit. It has longer gears and isnt good if your going turbo. The b16 Y1 tranny has shorter gears and is cable, so it might suit you better, but thats up to you.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 04-14-2006, 08:27 PM
2poor2tune's Avatar
yeah im sure i would like the b16 tranny better but cant afford it right now. and would you double check that whole "ls trannys are hydro" because i have seen some that were cable. it would be nice to be sure. and i always thought that longer gears would be better for the turbo setup because short ones cause turbo lag. and long ones have more spool time for the turbo. thanks
Old 04-14-2006, 10:08 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
no, not all ls transmissions are hydro, the '94+ ones are; but the older ones are cable. If you want faster acceleration, go with the shorter tranny. If you still want some kind of decent fuel economy, then go with the longer geared tranny.
Old 04-14-2006, 10:27 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Ok. I can tell you (because I have one) that the 93 integra tranny was hydro, so I would bet that all before are as well...also, the YS1 has some short freaking gears..the shortest of the cables Im told. The LS has very very long gears. Long gears are beneficial for a turbo set up not for spool time, but because you can stay in boost longer, before you have to shift gears..allowing you to get longer power boosts from your turbo, a shorter one would just have you spinning up the turbo and then blowing off any boost you may have made...
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-14-2006, 10:42 PM
SiZ's Avatar
SiZ SiZ is offline
Unless you're boosting 20+ PSI you're still going to be faster with a the shortest geared transmission you can get.
"The nympho of info, I'm fuckin' what ya heard"
Old 04-14-2006, 10:54 PM
2poor2tune's Avatar
cool thanks for the info. you learn somethin everyday around here.
Old 04-14-2006, 11:01 PM
CivicSpoon's Avatar
There is no Spoon
Put up 2 boosted cars that are exactly the same except one has a long geared tranny and the other has a short geared tranny. The short geared tranny will smoke the long geared tranny in the ¼ mile, on the highway to a specified mph, or exiting a tight corner. The longer geared tranny will give you a higher mph, that's it. And have fun praying, while you're trying to redline your boosted engine (reach the highest mph), that something doesn't give from all the heat you're producing. You don't gain hp by getting a longer geared tranny, but you get to your max power slower. Just more BS info that spreads through the world wide web.
Old 04-14-2006, 11:58 PM
FrodoGT's Avatar
Hey, I didnt say that you WANT the LS, there are other shorter geared ones that arent too short, I would never touch an LS, boosted or not......but a very short trans is not all too wise either...and sure, with our light cars, why not go for the shorty?...
Current project:
Rio Red 91 hatch.
Old 04-15-2006, 08:02 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
what? I'm hoping you meant to say the OPPOSITE! 93 integra tranny's are NOT hydro. ALL 90-93 integra tranny's are cable. FACT.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-15-2006, 11:19 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
s1, j1, ys1, and y1 integra trannys are all cable trannys.
so that makes the 90-93 teg trannies cable.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 04-16-2006, 12:55 AM
2poor2tune's Avatar
cool. thanks for the help. and isnt the ys1 the best out of them all
Old 04-16-2006, 09:38 AM
FrodoGT's Avatar
WHOA..yeah thats exactly what I meant! Cable cable cable..!
Current project:
Rio Red 91 hatch.
Old 04-17-2006, 06:32 AM
bambam89lx's Avatar
AF - Advisor
Best would be different for everyone. You have to ask yourself, do you want a higher top speed, or do you want faster acceleration. If you want a high top speed, get the 90-93 LS's A1 or USDM S1. If you want top acceleration, get the J1 or the Y1. If you want some happy medium in between, get the YS1. Not sure where the JDM S1 fits in all of that off the top of my head though. I know the Y1 has the shortest gears of ANY bseries tranny ever made, but it only has a 4.2 final. The J1 has slightly longer gears, but has a 4.4 final.
Old 04-17-2006, 08:35 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Are the YS1 trannies rare? I will be swapping eventually (like everyone else) but it will be awhile and I'm just going B18 most likely, but I don't want to go from a d16 to a slower b18 as far as acceleration goes...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
