Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 04-14-2006, 04:51 PM
phani_tavvala phani_tavvala is offline
Idle Problems
My Nissan 89 Pulsar is driving me crazy. It's the erratic idle problem. It was supposed to idle at 800 RPM and for past 1month it has been idling between 1300RPM and 1500RPM. Whenever I switch on my headlights and heater it sometimes (but not everytime) drops to 1200RPM. I changed my Oxygen Sensor, Spark Plugs checked for vacuum leak found a crack in one the tubes and changed it but still the problem is not gone. When I changed O2 sensor I have seen carbon deposit in exhaust manifold (Which is expected as the engine is running rich) I haven't checked for any seal leaks yet. And since the problem started I am also having 5th gear (by the way my car in a manual) popout. I changed the transmission oil and found no metal in it and I am guessing this is due to the engine pulsating sometimes. I haven't checked the stick and other links because I was hoping that I will address it once I fix the idle problem if needed. I am guessing that there is some electric problem because sometimes my headlight high beam turns on for few seconds and gets back to normal. Is this something to do with a relay or some OBD1 codes. I have not scanned the Computer yet? Do I need to? If yes where can I get it done cheaply. Please Help me
Old 04-15-2006, 05:16 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: Idle Problems
Idle Air Control Valve is your problem. Carbon buildup inside it causes the car to idle very high(it is basically like an electronic choke) and Nissan/Honda's are very common for it to have happen.
Remove the IACV and clean it with some throttle body cleaner.
www.pga.org.au should have some more info on how to clean it out for you.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
