Old 04-14-2006, 03:34 PM
makaveli3004 makaveli3004 is offline
Anti Theft Systems
Hey how come they dont make a switch or something that when turned on if someone trys to rob your system they will get shocked with a medium intensity electric shock
http://members.cardomain.com/makaveli3004 My 97 Camry
Old 04-15-2006, 08:44 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Anti Theft Systems
it's called lawsuits .......
Old 04-15-2006, 09:35 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
There is such a thing
Besides what paul said...
its also illegal in some states... though i dont see a problem with it. My friend used to have it on his truck. Somehow a policment found it out and he had like 30days to remove it or face some hefty fines. I live in FL.
Old 04-15-2006, 05:00 PM
So where do you go about buying something like this
Old 04-15-2006, 09:22 PM
CBFryman's Avatar
Banned
He personally made it. Transformer + Capasitor. not a real complicated circut. Get a transformer that can step voltage up from 12v to 300v+. Use the transformer to charge the capasitor. From the capasitorwire two plates seperated by just enough to keep them from arcing which are mounted on the inside of the exterior door handle. Or wire a row of plates. When you arm the system the transformer charges the capasitor. If someone completes the circut across the plates thenhtey will get a hefty shock. I wouldnt reccomend doing it without some good electronic knowledge. The capasitor should be able to handle your charge voltage and should be a low farad rating to keep the current on discharge low. you dont want any burns/cardiac arrest, just a jolt to the nerves. Also, you will need a way to discharge the capasitor when the system is disarmed or else when you try to open the door you will get a shock every time. I would draw you a schematic BUT i beleive that if you dont have the knowledge to build it yourself you shouldnt be building it for risk of killing/serisouly injuring someone.
There is a company that makes them. Dont know the name and i dont know if you can even buy them in the US.
