Go Back   Automotive Forums Car Chat > Volkswagen > Cabrio
Old 04-14-2006, 03:24 PM
Shellbo6901 Shellbo6901 is offline
02 cabrio driver side window stops
Anybody else have a problem with their windows stopping halfway up when nothing is in it way?
my dirvers side window stops halfway up, and goes back down, would this be a problem with the window safety feature?
Old 06-04-2006, 05:13 PM
95LT 95LT is offline
Re: 02 cabrio driver side window stops
My 2001 Cabrio had the same problem when I purchased it last year. My independent VW repair said that it would take a new window regulator at about $200 for the part to repair. I dropped it off and it stopped having the problem!
Good thing since some other items took up that $200
Best,
D
Old 06-25-2006, 10:23 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
I have seen this alot on cabrios.
There can be many of things wrong.
1) window improperly adjusted (yes you can adjust them on cabrios)
2) regulator is bad
3) motor is bad. The load sensor is actually in the motor itsself and if the car sits alot or over the winter the contacts can become corroded inside the motor and the module can pick this up and think its a hand in the window and stop and make it roll back down.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 11-13-2006, 10:21 AM
zdoyle zdoyle is offline
We had the same problem in both windows in a 2001 at the same time & like the previous post says, it was the regulator for both.
