Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 04-14-2006, 01:27 PM
Mad_Maxima's Avatar
Mad_Maxima Mad_Maxima is offline
Send a message via AIM to Mad_Maxima
Friends needs help, driveshaft trouble
Allright so my friend is trying to replace his driveshaft on his 90 300ZX and is having a couple problems. So we have to remove the exhaust from the cats back to be able to remove the driveshaft, but the bolts are super tough and there is build up in between the joints. We got one of the bolts off but the other nuts are kinda stripped, not completely though, but we still can't get them off. Any tips or tricks that will help us remove the exhaust any easier?
XBOX Live Gamertag: atxsbigwalt add me!!
Old 04-14-2006, 01:36 PM
86zx300 86zx300 is offline
Re: Friends needs help, driveshaft trouble
try to soak the bolts with wd40. also you can try air hammer to turn the headbolt. had the same problem before and thats how i did mine.
Old 04-14-2006, 01:37 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
^ what he said ^
They also have this stuff called liquid bolt remover... great stuff...
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 04-14-2006, 05:02 PM
Mad_Maxima's Avatar
Is the air hammer the only thing that will loosen these bolts? We have the exhaust removed but the bolts that connect the differential and the driveshaft are also hard to remove. All we have is WD40, a set of metric wrenches, and arm strenght. So do these bolts need some specialty tool, becuse I've read that people have done this job with only some degreaser and wrenches, but I'm having trouble believing they completed this job on their own.
Old 04-14-2006, 07:58 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
pb blaster/liquid wrench, time, and a lot of muscle
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 04-15-2006, 07:28 AM
AMNES's Avatar
AMNES AMNES is offline
I'd put some coke on the bolts, believe me it work's. Just make a hole in the bottle and sqirt it on. Do it a couple of times. I'm shure at leats 1 will go.
http://tuning18.c1.la
Old 04-15-2006, 01:50 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
i used PB blaster and standard set of metric wreched for all my bolts.
the bolts connecting the driveshaft to the rear diff are tough but they came loose for me with out any trouble.
ZedEx Crew Member #4
Old 04-15-2006, 03:00 PM
Scottie300z Scottie300z is offline
Send a message via Yahoo to Scottie300z
You have to remove the exhaust? I had to put in a new drive shaft myself on my 90 300zx and didnt have to. It was tight, but still very doable.
Old 04-15-2006, 03:12 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
have you tried yelling at it yet?
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 04-16-2006, 02:42 AM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
forget all that liquid spray --- use an acyteline torch and torch it ... it will come loose alot faster , the heat will make it expand.... thats what i use at work all the time on anything that wont melt and if im replacing it then ill melt away......
oh btw i dont think i spelled acyteline right ----
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
Old 04-16-2006, 11:04 PM
Kavorkian_Scarf Kavorkian_Scarf is offline
Send a message via MSN to Kavorkian_Scarf
I agree with both the acetlylene torch idea, and the yelling.
At least the yelling will make you feel better
If the bolts arent to stripped and you simply need to apply more force, just use a snyper bar.
Old 04-16-2006, 11:21 PM
Mad_Maxima's Avatar
Trust me we did plenty of yelling, lol. The bolts weren't too stripped but we replaced them anyway so once we got the old ones off we threw those bitches away. Our arm strenght wasn't enough so we had to settle for some WD40 and our legs, worked pretty good, only one bolt broke.
Good news is we got the one peice driveshaft, transmission mount, new hardware installed, and some light weigh reduction on his Z, so we we're both really happy. Took it out for a drive and everything ran perfect, no more annoying shaking at 60 MPH, back to one hand steering.
Old 04-16-2006, 11:24 PM
Thumbs up Re: Friends needs help, driveshaft trouble
excellent. Glad to hear that u got the work done and it fixed the problem
Old 04-19-2006, 03:27 PM
Hodo Hodo is offline
I used a 48" breaker bar and my lift. Seeing as knore I or my shop forman had any impact strong enough to get them out. But the good news is if you are replacing the stock 2 piece with a 1 piece you dont have to put them back.
Finaly got pics of my car....... after I washed it of course.
Old 04-19-2006, 04:31 PM
Mad_Maxima's Avatar
True, four less blots to put back on, freakin 2 piece, but getting them off was a definelty a bitch.
