Old 04-14-2006, 12:36 PM
Kebo33 Kebo33 is offline
Question How much oil to add to AC compressor?
I have taken the old compressor off.......but since the housing had a leak there is no oil in the compressor to see how much I should add back. The manual doesn't specify how much to use and the sticker under the hood just says to use synthetic oil......so how much should I add back in to the compressor before reinstalling? I am also replacing the dryer.
Thanks,
Kebo
1999 Chevy Blazer LT
4.3 V6 2WD
Old 04-14-2006, 01:27 PM
billibong's Avatar
billibong billibong is offline
Re: How much oil to add to AC compressor?
Are you replacing the compressor, or just reinstalling the old one?? For a new compressor I added one small can of oil - 4 oz? - and two cans of r 134a, 12 oz.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 04-14-2006, 01:36 PM
blazee's Avatar
blazee blazee is offline
Problem?
I would suggest a complete refill, because after a compressor body leak, you can't be sure how much oil is still in the system. You should install a new orifice tube, too, that way when you remove the old one any oil in the evaporator will drain out too. When you put it back together use "PAG150" oil in the pour bottle. Spread it out by pouring it in different parts of the system. Add the majority to the compressor and turn it by hand to allow the oil to coat everything. You don't want the compressor to dry start under load.
Old 04-14-2006, 01:37 PM
I am installing a new one.......I tried to find a place to rent a vacuum pump but no one seems to rent those. I read another post that said to use 8oz. 6 in the compressor and 2 in the dryer. Any thoughts? And if you didn't pull a vacuum, how well does your system work?
Old 04-14-2006, 02:08 PM
billibong's Avatar
I did have a friend pull a vacuum on the system, to make sure it was completely evacuated. I replaced the orifice tube, also. You definately should, because if you don't the warranty is void on your new compressor.
I used the PAG150 oil and did like blazee suggested, it might have been an 8oz bottle. I used the resources I found on this site to do it right. Quite a few of these guys have a lot of hours under a hood, more than I do.
billibong
Repairs:
Old 04-14-2006, 05:57 PM
Where does the orifice tube go on a 1999 Blazer?
Ok, I have the compressor and the dryer changed out.....but the manual doesn't tell me where the orifice tube goes. Can anyone help me out?
Thanks, Kebo
Old 04-14-2006, 06:13 PM
blazee's Avatar
Problem?
Re: Where does the orifice tube go on a 1999 Blazer?
It's in the line where it enters the bottom of the evaporator.
Old 04-14-2006, 06:15 PM
Let me guess.....that is under the dryer going into the airbox? If so, that will be a "mother" to get to.
Old 04-14-2006, 06:17 PM
blazee's Avatar
Problem?
Its not bad. The evaporator is in the black box on the firewall,, but the line connects outside of the airbox. Just remove the line and the orifice tube is stuck right in the tip of the evaporator.
Old 04-15-2006, 01:27 AM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Where did you get your new compressor from? I have to do all this soon as well.
Old 04-15-2006, 09:17 AM
I got the compressor, dryer, and orifice tube at Advanced Auto Parts. I think the total was $335. The compressor was a rebuild with a 2 year warranty. You can find them online at www.partsamerica.com.
Old 04-30-2016, 02:37 PM
stuckryan stuckryan is offline
question on the process
ive read to pull vacuum before charging it
if i put oul in the compressor and pull vac wont that pull the oil i put in out ?
