Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-13-2006, 11:06 PM
DenisM DenisM is offline
RPO UF7 gauge package
I have the base cluster in my 87, and I want a set of gauges without hacking my car up. Would the upgraded cluster fit in place of the base cluster without serious modification? Im looking to just unplug and plug back in. How easy would this be?
Old 04-14-2006, 12:40 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: RPO UF7 gauge package
That won't be a plug and play situation, unfortunately, as you will have to change the wiring under the dash as well.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-14-2006, 10:14 AM
what would have to be changed for wiring? i would probably have to change the temp. sending unit, but i looked up a schematic, and it only showed one for the gauge package, so i figured they were both the same.
Old 04-18-2006, 09:22 PM
TommySS TommySS is offline
An easier solution would be to remove the dash pad, unbolt the trim plate over the glove box and install your gauges in the trim plate. There's plenty of room for up to four conventional gauges. There are adapters that allow an angle mount so they will point to you. I bought a new trim panel before hacking up the old one just in case I wanted to return it to stock.
Old 04-18-2006, 09:29 PM
silicon212's Avatar
Confoundingly Lucid
The 1985 @ newer dashboards do not have a removable trim plate - it is an integral part of the dash assembly.
Find a set of 9C1 gauges, get a Dremel and cut out the area of the dash where the cigarette lighter is, and set those up. The bonus of this is that you can find a 9C1-style 'certified' speedometer to put in your current cluster without modifications (120mph vs. 85mph). You can't do that with the UF7 cluster as the speedometer is of the round type (ni a square mount) and smaller.
This is an example (but the pic isn't that great for detail) of how Chevy prepped the 9C1 cluster - note the gauge set where the lighter would be, and the lighter (not in the picture) moved to the other side of the radio cluster.
