Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 04-13-2006, 03:51 PM
ComputerGeek11s ComputerGeek11s is offline
How to install a msd ignition coil in a 04 Corolla
I was wondering how to install a performance ignition coil such as an msd coil in a 04 corolla. My email address is [email protected]
Old 04-17-2006, 12:34 AM
asn13oy asn13oy is offline
Re: How to install a msd ignition coil in a 04 Corolla
The stock ignition system is already optimized from the factory. It would be difficult to see any real gains from upgrading.
I don't think anyone even makes aftermarket coil packs for the 04 corolla (or 00+ corollas for that matter). The ignition coils for the 1ZZ-FE sit directly over the spark plug, in the manifold cover.
Old 04-17-2006, 01:41 AM
Well what else can I do gain more horsepower from the engine. I have installed a modified turbo kit with no lag. Do you think buying highperformance pistons and camshaft will make a difference. Can you add a some type of MSD component of some sort to optimize the ignition. And where would I go to get the most high performance piston and camshaft for a 04 corolla.
Old 04-17-2006, 02:19 AM
joykill joykill is offline
soo...did you or someone else install your turbo...cause it seems like you would be able to answer all of your questions if you installed and modified your turbo...
671 ISLAND ROOTS
Old 04-17-2006, 02:49 AM
No one makes cam shafts for the 1zz-fe. Monkeywrenchracing.com (a site you should definately check out if you're interested in rebuilding your engine) tried to design one but it ran like crapt, so they dropped it.
But, the same company makes or sells complete rebuild kits for the 1zz and 2zz engines (or just the pieces). You should definately check them out.
Also, try "9thgencorolla.com".
Old 04-20-2006, 01:12 PM
rice(er)'s Avatar
rice(er) rice(er) is offline
dude, if you got turbo, then turn up the boost f0r t3h Win!!!!!! homie!
Old 05-17-2006, 12:36 PM
fastcorolla fastcorolla is offline
lol dont run to much of high boost unless u lower that compression! and i hope u have already optimized ur ECU...
