| Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here. |
Drift Question
Hello,all im a newb to drifting and i think of getting either a 89-94 240sx
or a 95-98 240sx.well i just wan't to know what are the steps to make a drift car. |
Re: Drift Question
driving skill, good suspension, performance
-Matt NISMO ![]() 1992 240sx SE Fastback 5speed ![]()
Re: Drift Question
LSD driver suspension in that order
Re: Drift Question
do this buy lsd then buy coilovers then subframe bushings tie rod ends and tension rods. nismore front power brace and nismo motor and tranny mounts and that shold be more then enough to get you started actually that pretty amazing of a setup. and will take you a long time to get but thats some good shit to have
Re: Drift Question
Better yet, get a clapped-out S13, FC3S, or whatever beater and practice with it. Then start worrying about a nicer ride and more spending. I won't get into my opinions on drifting in and of itself....
1968 Mustang notchback Roller 302, Edelbrocks, Hookers, side-exits, RRs, Crane 2031, Duraspark, forged slugs, X-Celerator, 650DP, Fidanza FW, RAM clutch, Toploader, Comp Plus, McLeod bell, 15x7s, 1 1/8 swaybar. 1972 Ford Pinto SVO 2.3 turbo, MegaSquirt, T5, 8", etc. '95 Honda XR600-10.5:1, 628cc, ported head, & more. |
Re: Drift Question
Yeah an LSD is a must, It wont shift lock very well without one.
"If God were suddenly condemned to live the life which he has inflicted on men, he would kill himself" -Alexander Dumas (1802- 1870)
Re: Drift Question
used vlsd or weld the stock diff. you dont need to worry about engine mods till your a little higher on the skill ladder. sure you could just do intake/exhaust at first, but i would invest into some supension first
"I wish there was a knob on the TV to turn up intellegence. There's a knob called "brightness," but it doesn't work." -Gallagher still need a car...so sad
Re: Drift Question
why do some many people rock a welded diff? Whats so good about them?
Re: Drift Question
they cost next to nothing. and they have the same effect of a 2 way
Re: Drift Question
Dont they have a chance of breaking or something like that...and lsd's arent always locked
Re: Drift Question
well if a 2way locks up on accel and deccel, its pretty much the same affect as welded or locked always.
1988 conquest TSI -Lots of mods, finally finished WOOT!! ![]() Horsepower sells cars, Torque wins races! |
Re: Drift Question
Except that a welded differential does not slip when going around turns; it's like running a spool. With a stick-axle rear end, it usually just makes the inside tire "chirp-chirp-chirp" when turning. I imagine it's alot harder on IRS like the 240 has.
Re: Drift Question
welded diff is baisically a 2 way with 100% lock all the time. if your car is a daily driver, itll be a little hard with daily driving. it can be used for daily driving, but like speedfreak said the inside wheel will chirp a bit.
as for breaking, ive seen a lot of welded diffs and people said they last for a while. but evin if it breaks hey at least it isnt an $800 diff out the window
Re: Drift Question
Hmm why does the inside tire chirp and how does this effect cornering?
Speedfreak what does IRS mean? |
Re: Drift Question
2. IRS = Independent Rear Suspension.
