Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-13-2006, 02:00 PM
axekick's Avatar
axekick axekick is offline
engine rattle
My 94 240 has a rattle after it gets warmed up. The noise sounds like it's under the valve cover in the front of the engine. To describe it better, if you didn't pop the hood and check, you would think it was a loose pulley. Under the hood however, it almost sounds like something is hitting the front of the valve cover. Any ideas?
Old 04-13-2006, 05:06 PM
rps13freak's Avatar
rps13freak rps13freak is offline
Re: engine rattle
it may just be the lifters tapping. is it loud or kinda quite?
Thats one sexy car!
1989 nissan 240sx
Old 04-13-2006, 06:08 PM
Skylindrftr Skylindrftr is offline
Send a message via AIM to Skylindrftr
Re: engine rattle
its the lifters i think, its a common 240sx ailment
Old 04-13-2006, 08:16 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: engine rattle
^ i'd put my chips on it. its still gonna be driveable but i'd recommend replacing them..
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 04-13-2006, 08:52 PM
axekick's Avatar
Re: engine rattle
You may be right, but the sound is not so rythmic. After I posted this, I searched the forums and found a few people who had problems with a timing chain guide. The symptoms match, It got low on oil, started making the noise, and I put oil in and the noise never went all the way away, exept that when its not idling you it sounds fine and when it's cold. But from reading similar simptoms I'm led to believe that it just makes the noise when the oil pressure is low. Someone said you can take the guide out and leave it out. Is that true? Can I take it out by just removing the valve cover? Thanks for your advise. If I'm just wrong, tell me. I'll take you're advise if you still think it's the lifters.
Old 04-13-2006, 10:20 PM
nissan_240sx nissan_240sx is offline
Re: engine rattle
Yes you can take off the guides, there's 2. One on the top you could remove by just taking off the valve cover, and one more I believe on the distributor side ( lower right ) you have to take off the front cover to get to that one. Good luck
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 04-14-2006, 04:00 PM
orestes's Avatar
orestes orestes is offline
Re: engine rattle
i never understood how you could take off the guides and it would still be ok, but that does seem to be the common consensus
"I got that hustle in my genes like high blood pressure" -E-40
Old 04-14-2006, 10:31 PM
Re: engine rattle
Yup. Took mine out a long time ago, and the rattling was gone. To me the guides are pretty useless, the tensioner alone is good enough to hold/guide the chain
-Matt
NISMO
Old 02-10-2008, 11:04 PM
blk91240 blk91240 is offline
Re: engine rattle
hey: does the noise go away when you rev the engine, say 2500 rpm?
gd what? gdsr boyz: GOD DAMN STREET RACERS!
Old 02-11-2008, 09:09 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: engine rattle
Old thread, please dont bring up dead threads. Any questions, please refer to the forum rules and guidelines.
Closed Thread
