Originally Posted by mattiscool28
I was told that i need to get a steering box for my 1994 caprice LT1, i just changed the powersteering pump and it seems to be working fine, and they just did the alignment, but the car still slightly pulls to the right, how do i know if i need a stering pump, and would that cause the slight pull? also could anyone give me some prices on steering pumps? thanks in advance
If they just did an alignment on it, and it still pulls, chances are you've got a tire about to go south. You could also have inflation differences (they should have checked that during the alignment procedure), or two different sized or type tires on the same axle (again, that should have been checked for). My bet is on a tire that's beginning to separate. As for the gearbox (I'm assuming that's what you meant), you'd need that generally only if there's a lot of play in the wheel, or it excessively leaks. The pump itself has nothing to do with the alignment of the car or any pull.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at
http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
