Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 04-13-2006, 11:01 AM
fossil123's Avatar
fossil123 fossil123 is offline
Oil Talk - 2002 Jetta......Need Advice!
I just bought a used 02 Jetta and its about time to have the oil changed. My dealer told me I could go every 5,000 miles on Casterol,which I did. Does everyone here do the same thing or just go with the regular oil and change every 3,000? What's the advantages to both?
From what I have heard, Jettas are hit and miss when it comes to quality, so I don't want to screw something up. Thanks!
Old 05-22-2006, 08:03 PM
FemaleVwTech's Avatar
FemaleVwTech FemaleVwTech is offline
Post Re: Oil Talk - 2002 Jetta......Need Advice!
Is it a TDI, VR6, or 1.8T? If it is a TDI, you need to use Casterol. I would rec. using Casterol in the other two, also. Casterol is a better oil. You change you oil every 5k. Don't go any longer than 5k.
It is a 2.0L? I would go not longer than 5k, but it would be better if you change it at 3k beacause some of the 2.0L have a small oil burning problem. I would aslo rec. using Casterol.
I have two 1.8T Jettas. I always use Casterol and change it every 5k.
Old 05-23-2006, 09:18 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Can only go 5k if using synthetic.
3k on normal oil.
Just make sure to check oil level every 1000 or so miles.
