Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 04-13-2006, 10:06 AM
LI-SVT LI-SVT is offline
Part Throtle Ping
My 2002 LS V8 sport pings with the gas pedal half to three quarts pressed and RPMs above 3500. More throttle and no ping. It is a little worse using the manual shift. Of course Lincoln service can not duplicate the issue I am using 93 octane fuel and am at sea level. Brand of gas does not matter. In the summer heat the problem gets worse.
I have read a few threads where others are complaining of similar problems. I don’t like it and am looking for a solution for making it go away
P.S. Don’t these cars have knock sensors? I have a scan tool, any ideas on which PIDs to monitor would be helpful.
Thanks
Old 04-13-2006, 06:13 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: Part Throtle Ping
Are you confident it is a ping and not a misfire? Do you feel the engine bucking, or just hear a slight tapping? Does you scan tool have the I/M Readiness and does that show any misfire counts for any of the cylinders, even if no cylinders fail?
-Rod
Old 04-17-2006, 07:35 AM
No misfire, it is knock/ping.
Old 04-18-2006, 08:48 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Mine has always done this. Well...until I got the Xcal, anyway.
Too much "vacuum" advance. Not sure what it's called now, but it's the part throttle advance that used to be vacuum advance back in the day.
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
Old 04-18-2006, 02:19 PM
So with the XCal you removed some part throtle spark advance, but left the WOT setting alone?
Or did you remove a global amount of advance, like twisting the distributer?
I would hate to have to give up full throtle power in echange for less pinging. The car never pings at WOT.
Old 04-18-2006, 03:42 PM
CGGorman's Avatar
I just pulled some light load/low rpm advance. My overall performance is improved and so is my driveability.
