Installing Driver side window regulator
My driver side power window has been broke for awhile. Took the panel apart and found out i need a new window regulator. Online the best i can find for a new one is around $200 bucks. Dont wanna go with an old one. Anyway i called up a place near me to see what they charged to get the part and install it.....$670! wow. They said the part cost them $400. Bullshit. Anyway i was just gonna get it for $200 and try to install it myself. Has anyone done it? And is it easy to do? Thanks.
93 Base 3000GT Injen Intake Power 1 exhaust tips Polk audio speakers |
Re: Installing Driver side window regulator
http://trademotion.com/partlocator/i...odel=3000%20gt
http://www.stealth316.com/2-door-panel.htm quoted from someone on 3SI "pull up the window by hand. fold over a rag a few times and put it on the edge of the window and use a wise grip to clamp it down or have someone help you hold the window up. dont clamp it too hard though. remove the 2 nuts holding the rail the glass. then remove the 3 holding the motor to the door, remove the 2 holding the frame to the door. take everything out, and replace it. you will have to twist thing around a bit to get things into position, then screw things back. its not that complicated." so it doesn't seem to be too hard, i've never done it so i couldn't tell you its "difficulty" level, but it seems pretty easy none the less
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Thanks for the info. Gonna buy the part now and use that guide. Thanks.
