| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Bastard 20g is it overkill on my fwd
Ok im in the process of doing little upgrades to my car. im dropping my tranny and putting in an sbr lsd insert next week. and getting dsmlink and bigger injectors in about a month. and been looking at this http://www.slowboyracing.com/more.php?id=1977&
pretty sleeper turbo since its in the tdo5h. but i think it will be overkill. i might not be able to keep my tires from spinning when i hit boost. i just want to hit 12's i dont care if its 12.999 i just want to hit it. or should i look into 50trim's. what do your guys think?
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
Re: Bastard 20g is it overkill on my fwd
12's on a FWD should be pretty attainable on that turbo. I think you should be ok as long as you get some stickier tires up front. IIRC, theres some street legal drag radials by BF goodrich or bridgestone for fairly cheap (~$100 per tire).
...this goes in the performance sub-forum...
Wow, I never saw that turbo before. What are the specs on that beast? (Spool time, max, supporting mods needed, approx. 1/4 times, good daily driver)
![]() 2006 Wicked White Evo IX GSR 323 awhp / 311 tq. (Dynojet) http://www.projectevoix.com http://www.4WStuning.com 99 RS < 98 GSX < 06 EVO
I'd choose a 50 or 60 trim over that. I'd like to see some copressor maps if they're avalible.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
A 20g wheel is a 20g wheel, no matter how you slice it. 48 lbs/min max flow. If you are worried about wheel spin when you hit full boost, you might consider a 6H variety, which I prefer anyway for the added VE. I'm not a big fan of big wheels stuffed into small housings, and prefer the full 6h 20g, but that's just me. Everyone has their own set of goals and priorities.
To answer the original question, a 20g of any type is not overkill on a FWD, in my humble opinion.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Yeah the 20g would be perfect, or a 50 trim. Either one, in my opinion, would be a good choice. I think the 60trim would be overkill unless you are planning on making huge power with lots of boost. Get the 20g....
Edit> I just looked at your mods list and am wondering why you are wanting to do an upgrade? The EvoIII 16g GT should be able to get you into the 12's easy...why not just tune that? Bigger injectors and some sort of tuner +slicks equals 12.XX Even what you have now plus slicks equals 12.XX
![]() 05 Srt4 Agp 3147 w/supporting mods ![]() 97 Mx-5 T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box, |
when i mash on the gas on the stock t-25 turbo my tires loose traction.Im only boosting 13 psi. Im sure its my tires though. Even though they only have around 1000 miles on them. The tire is made by Fuzion. Anybody heard on them?
1997 Eclipse GS-T Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head- Interior Modification:-Autometer Boost Gauge http://www.cardomain.com/id/xTeamRedLine23x |
man i just want a 20g, ill see what happens, im getting dsmlink in about 2 months so that should help me out on the tune side. hopefully i can hit that 12
that's because the power delivery on the T25 is instant, your tires can't take them, plus those are shitty but with a big turbo, that delivery is slower, but a lot stronger, it just depends on spool time and tire with a big turbo.
now - 2000 civic soon - 2002 is300
Hey if you do end up getting a new turbo Ill buy your 16g off you. PM me if you are interested.
Darn. Looks like Im stuck with the 14b for another day
not a bad turbo to be stuck with when you consider the stock turbos of some other cars
(VW for example)
I guess in the end I should be grateful I have a turbo at all
