Old 04-12-2006, 10:12 PM
yackel yackel is offline
WS6 Package
I searched and didnt really find what I was looking for, what was included in the WS6 package on the 3rd gen Firebirds? I ask because my 82 Trans Am parts car has WS6 on it. I have a 86 Firebird base model I drive well used to drive before the 6 cyl went out on me. thanks in advance
Old 04-13-2006, 12:23 AM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
Re: WS6 Package
l didnt know there were WS6 pacgage on 3rd gen bird..
Old 04-13-2006, 01:13 AM
Re: WS6 Package
I dont know if there is or not, im not really a gm person this is my first gm product. I seen WS6 on the car and searched it on google and found it as an option but what it consist of is what im tryin to figure out.
Old 04-13-2006, 02:03 AM
doodad's Avatar
Re: WS6 Package
do not worry man, you will get answer to your question.. we got some real cool guys here..
Erdal
Old 04-13-2006, 10:36 AM
tuske427 tuske427 is offline
Send a message via AIM to tuske427
Re: WS6 Package
The WS-6 option is the optional performance suspension package for the Trans Ams and Firebirds. Stiffer springs, stronger anti sway bars, better performing shocks, etc.. The WS-6 also involves 4 wheel disc brakes.
Even the 2nd gen cars had the WS-6 option, too. It just wasn't marketed strongly until the 4th gen cars with badges, etc.
I was told on the third gens anyhow (someone correct me if I'm wrong) that the "WS-6" is the performance suspension plus 4 wheel disc brakes, the WS-7 is the performance package with drum rear brakes.
So- check the springs and sway bars on your parts car. If they're original they will be thicker. (Use a caliper to measure) You can add them to your firebird if you want a stiffer ride. Just note that you'd be adding springs designed to hold the weight of a V-8 engine on a car with a v-6 inside. It may become too stiff and actually hurt your handling. (Yes, it is possible to have too stiff a spring. you should consult with someone who builds race car suspension, or at least get more opinions on this before you do it) Maybe just swap the sway bars with the '82 pieces?
do you plan on making a v8 engine swap in your '86? If yes, definitely upgrade the suspension.
At the least remove them from the car before you sell it/ junk it. Also check the rear axle- it may be a posi unit. Also worth keeping.
I hope this is helpful.
Long live the muscle car
Old 04-13-2006, 06:48 PM
2000LS1Z28 2000LS1Z28 is offline
Re: WS6 Package
Here is what it consisted of:
WS6 was standard an all Formulas in the 3rd generation.
16-inch polished "Pontiac Snowflake" aluminum wheels
R-rated tires from the factory
Tear-drop cowl hood
Larger front/rear anti-sway bars
Stiffer shocks
Tigher ratio springs
Dual oulet mullfer
*Note: the WS6 package changed slightly in 91-92, as did the entire car, but changes are minor:
16-inch five-point wheels
36MM Front Stabilizer Bar
24MM Rear Stabilizer Bar
Performance Bushings
As can be viewed here:
http://blackws6.20m.com/about.html
2001 MR2 Spyder
Magnaflow Muffler and OBX CAI.
Old 04-15-2006, 07:21 PM
Re: WS6 Package
Thanks for the info guys. I am swapping the V8 engine in after I find a bell housing and a couple other trivial parts. I went out and did some measuring and looks like the only thing on the car thats off a WS6 is the rims, my 6 cyl has bigger rear stabilizer bar than the trans am does. Does any body know how to tell the difference between a 305 and a 350?
