Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-12-2006, 09:37 PM
b00stedspYder b00stedspYder is offline
Possible boost leak....please help
ok ive been having major problems with boost leaks with my gst...but i finally fixed them all! problem is i still cannot hold pressure, why is this. i tested over and over again and found no leaks all the way up to the tb, what could be causing this??
Old 04-12-2006, 09:46 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Possible boost leak....please help
have you checked the injector seals?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-13-2006, 12:20 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Or the throttle plate shaft seals. Or intake manifold gasket.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-13-2006, 12:33 AM
joemathews's Avatar
joemathews joemathews is offline
What are you using to test? Soapy water sprayed on the problem areas? Listening for air escaping doesn't always reveal all of the leaks.
Pressurize the system, drop a few drops of soapy water on your injector o-rings and see if they bubble. Otherwise, the shaft seals are probably your culprit.
1996 Eagle Talon
Old 04-13-2006, 09:03 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
If I can't find a leak I take it 1 pipe at a time. First test from your throttle body, then your uicp, etc...that will find the culprit
now - 2000 civic
soon - 2002 is300
