Old 04-12-2006, 09:37 PM
dustinlmiller13 dustinlmiller13 is offline
Question PLEASE HELP! Bracket problems.
Please help guys. I have a 1980 Camaro with a 350 sb. It used to have smog heads with the accessory holes in the heads. I bought a set of rebuilt double humps without accessory holes. I found some power steering brackets that would allow the power steering pump to bolt up to the drivers side of the water pump and block. But my real problem is with the alternator brackets, I cant find any that will let the alternator bolt up to the passengers side of the block and water pump. There has to be someone out there that has had this same problem. What did you guys do? Or what would you do? Thanks for any help.
Anything is possible through Christ our Lord.
1980 Camaro: Base coupe sleeper with 350 4bolt main (stock bore, double humps, 480 lunati cam, flowtech headers). Stock 2.73 open rear (changing next month to 4.10 mini spool).
Old 04-22-2006, 10:22 AM
wayne76 wayne76 is offline
Re: PLEASE HELP! Bracket problems.
you can try March or even summit that is expensive. Depending on your area any local machine or performance shop could point you in the right direction. sorry cant offer anything better
