Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 04-12-2006, 07:22 PM
DESMONE DESMONE is offline
B18A1 into 94 del sol?
I have a 94 del sol (1.5, standard trans, base model car) that needs a motor and a '90 B18A1 (from a '90 integra RS automatic) that needs a car. Is this a bolt in swap? can I use the ECU from the integra? What do I need to do? Thanks in advance for any advice.
Old 04-13-2006, 03:15 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: B18A1 into 94 del sol?
No, no, and no. 1992 is when Hondas went from OBD0 to OBD1. You don't want the headache of doing the conversion. Trust me. It's a bitch. I've done it before. And also, if you're in an area that does emissions, your car will no longer pass emissions with a motor in it older than the car. Save up your pennies and get a B18c1 if you really want the integra motor, or get a B16a3.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 04-13-2006, 03:56 PM
Thanks for the reply! As far as the d motor vs the b motor, are the interchangeable or are the trannies different for example, if I got a b18 of the newer type, will that be a plug & play swap? can I use the trans from the del sol with a newer b series? Can I use the b18a1 block & head with a later intake & emmisions etc. Thanks again!
Old 04-16-2006, 12:18 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
no you cannot.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
