Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-12-2006, 05:38 PM
GreyGoose006 GreyGoose006 is offline
Transmisson Problems
my 84 caprice classic is having transmission "issues"
it is not shifting into 3rd gear on the highway, and i have to get it up to around 75 or 80 before it is forced to shift into 3rd gear sometimes. i've lengthened the kickdown cable an inch and it helped, but at times, it still likes to stay in 2nd gear. this is really hurting my gas mileage, so any help would be great.
Old 04-12-2006, 06:19 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Transmisson Problems
Only a TH350 has a "kickdown" cable, or detent cable. The cable on an overdrive unit (TH2004R, 700R4) is called a "Throttle Valve" cable, a valve controlled by position of the throttle - in addition to detent downshifts, this cable replaces the old vacuum modulator. You MUST adjust this properly or you can DESTROY YOUR TRANSMISSION! With either the TH350 detent cable, or the TV cable on the 200C/4R/700R4, adjustment is performed by pressing the clip in on the cable where it attaches to the carb/throttle body (it's a D-shaped steel clip) and pulling the cable back to the firewall as far is it will pull, and then wide-opening the throttle.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-13-2006, 03:16 PM
Um... Yeah, i thought this would be obvious but i do in fact have the TH350 three speed transmission.
Old 04-13-2006, 03:24 PM
silicon212's Avatar
Confoundingly Lucid
Actually it wasn't obvious as most '84 Caprices have TH700R4 transmissions, buy yeah ... you still need to properly adjust the detent cable - if it's too tight, the transmission will assume the engine is under a power demand and will raise the shift points. Also, the vacuum modulator can have some issue as well, check for vacuum and make sure the engine is running good too. On a car with a vacuum modulator, if the engine drops a cylinder, the transmission shift points will raise and become harsh.
