1993 5.7 350 vibration
when in gear and stopped the engine vibrates very badly. it doesnt do it in park, or neutral.
when i press the gas to go, all of this vibration stops with no sign of any vibration. the car has 78k miles on it, adn i havent had it long. does anyone have any tips? will new spark plugs solve this? |
Re: 1993 5.7 350 vibration
Idle speed adjustment, vacuum leaks, worn or slipping transmission, all of these can cause these symptoms. So can low cylinder compression. Check condition of all hoses and see if that helps.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
You have a bad trans mount.
91 Caprice 305 700R4 2.56 225/70R15 |
You have a bad transmission mount.
