Old 04-12-2006, 02:46 PM
classicrepair classicrepair is offline
99 3.8 oil pan gasket replacement
Hey anyone done a oil pan gasket replace on 3.8 Camaro here, if so is it hard or fairly easy? Also I bought the pan gasket and its a solid plastic piece and very strange looking. Is this stock because I have a cork one on it now and has no middle tunnel thing attached to it.
Thanks a mill
Scott
Old 04-12-2006, 02:59 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: 99 3.8 oil pan gasket replacement
I dont know about the material of the gasket or about the 3.8 specifically but on the z28 models people usually unbolt the mounts and jack up the engine and then loosen the bolts for the k member so that it can be lowered and then you should have a clear shot at it.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 04-12-2006, 06:04 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
I have never done mine, so can't help ya on what it should look like... although if you kwno the odl one was cork then I assume you have it off already. Line the new gsket up on the pan, make sure its the right size and shape and the holes all line up, if so I would guess that it'll work.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
