Go Back   Automotive Forums Car Chat > BMW > Technical
Old 04-12-2006, 01:41 PM
peter05 peter05 is offline
Unhappy autogearbox on 740
I am having aproblem with the auto box on a 1995 740 that has afull bmw service history and which has just covered 55000 miles. When the car is driven from a cold start the gear change is very jerky and it feel as if the box does not want to change and will stay in that gear, on 3 or 4 the change is quite bad and then as soon as the car warms up this smooths out, any answer
Old 01-12-2007, 01:19 AM
ZONDERVANUS's Avatar
ZONDERVANUS ZONDERVANUS is offline
Thumbs down Re: autogearbox on 740
I have the same problem...
I was told and forewarned prior to purchasing this '94 740IL three weeks ago that these cars are problematic.. transmission slips... check engine light comes on and runs rough... I think that my tranny is bad.. it feels as though i had a manual tranny whose clutch is slipping...
BMW 325i E36
Old 08-31-2007, 07:46 PM
littleMSG littleMSG is offline
A get a valve body rebuild kit from ZF. I've fixed many with this problem as long as there not slipping or slipping bad. Vehicle most still shift in all gears including reverse. It's worth a try. The valve body isn't hard to get out, but very messy. The rest is done on a clean work bench. Kit comes with directions on replacing the springs and check balls. This is very common on all bmw V8 models 95-98.
