Old 04-12-2006, 11:22 AM
spivey-1 spivey-1 is offline
gas mileage ?
Can an exhaust leak cause your MPG to go down. If so just how far can it bring it down.
Old 04-12-2006, 02:08 PM
RahX RahX is offline
Re: gas mileage ?
Yea it can. It can make the O2 sensor think the engine is running too lean and the pcm will dump more fuel in to compensate for what it thinks is a lean condition. It will MURDER your gas mileage if its a good leak.
Old 04-12-2006, 03:23 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: gas mileage ?
it will also lack power, and cylenders close to the leak will run hot enough that you can accually blow a hole in the piston itselfe, exhause leaks by or at the manifold should be fixed asap
