Old 04-12-2006, 09:54 AM
IH8Deuces IH8Deuces is offline
1998 Sunfire: DRL, one dim headlight?
I am the owner of a 1998 Sunfire Convertible, 2.4L.
Driver's side headlight is very dim while the passenger side is normal brightness, both under normal and high-beam operation. Also the Headlamp/DRL indicator clicks and flashes repeatedly during daytime operation unless I turn on the headlights.
I replaced the halogen bulb with new ones twice and also switched it with the working one from the passenger's side. Confirmed it is not a bulb problem as all 3 bulbs have worked properly on the passenger side.
If the DRL relay were faulty could it cause just one headlight to behave like this? Is that something that is available at an auto parts store?
What else can I check - socket, fuse, ground wire ?
Old 10-10-2006, 05:22 PM
theliquorbucket theliquorbucket is offline
Re: 1998 Sunfire: DRL, one dim headlight?
i have the same problem oyu have. have you found a solution to the problem yet??
Old 10-10-2006, 05:50 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
you shouldnt ask someone a question from 6 months ago, you probably wont be getting much of a response, for starters you could try replacing your Daytime Running Lights relay, a bad one of those will cause the headlights to do some weird things....
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-10-2006, 06:34 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Yes if only one of the lights are dim then check you relays, ground wire, and also any other wires in the harness that could be frayed, cut, split etc etc.
